Can we dehydrate our food?
ToolNatural materials
Options to dehydrate food that we already have
In the oven
We can use the residual heat from the oven to dry out food.
Issues with this: we only light the oven twice a week, so could only use this method twice a week; actually only once a week cause one of the times is friday nights, where we are up late using the oven for pizzas. There is also no easy way for moisture to escape using this method (although with our pizza oven this might be a bit different). The higher heat could also be less desirable for herbs.
In the storage container
We have been using the storage container for drying herbs quite successfully, however it can get a bit messy + we cannot use this method for other kinds foods, and there is the issue of maybe rats being present there and possibly contaminating the foods drying there, if there are not closed of properly.
Out in the open
Earlier in the season we had a lot of oranges from a neighbour (see oranges video). We tried drying some of the oranges by cutting them into slices and hanging them out to dry. We did not consider that this came with some problems: it gets humid at night so the slices got moist again every evening, insects would sit in them,..
→ Possible solutions:
- use screens that we cover for the insects and taking them into the storage container every night to keep it from getting humid again
- build a closed container specifically designed to dry food efficiently with the sun: a solar dehydrator
Solar dehydrator
A solar food dehydrator is a device used to remove moisture from food using the power of the sun. Solar food dehydrators are a low-cost alternative to electric food dehydrators.
Drying is an excellent way to preserve produce, but exposing fruits and vegetables to direct light can cause vitamin loss. Solar dehydrators rely on indirect solar power, meaning the drying food is not exposed to the sun but instead to solar-heated air.
What is the purpose of having a solar dehydrator
- Easy way to process big batches of food (good way to use up local overproduction of zucchini, tomato, oranges, …)
- Dehydrated food can be stored for a long time
- Dehydrated food takes up less space
- Actively combat food waste
- Less energy-intensive than canning/other preserving methods (energy-intensive both for humans and for literal energy as in gas/electricity)
- Availability of summer produce in winter; for example: dried zucchini/tomatoes can be used in tons of winter stews/soups/baked goods to add extra vitamins/minerals/flavour
- More nutrients are preserved when dehydrating food vs canning
Examples of solar dehydrators and materials needed
- https://www.motherearthnews.com/diy/solar-food-dehydrator-plans-zm0z14jjzmar/
Pros: this dehydrator has wheels so is easy to move
This person did a lot of research into solar dehydrators and different models and this design is the result of that research
The dryer takes advantage of the natural process of rising hot air to operate efficiently without any electric fans
- https://solar-food-dehydrator.com/#learn
The models from this website are very interesting and well researched: both models have interesting features
- the Wheaton ATC1 food dehydrator model has an extended solar collector, allowing for faster drying
- the Missoula food dehydrator model has an overhang for weather protection & enclosed sides to stabilise temperature fluctuations which could be an interesting choice for Kamp
Building a solar dehydrator
We looked at different designs online. A good solar dehydrator does not expose the food directly to sunlight (which could lead to a loss of nutrients) but works by conserving the heat on a dark surface and airflow moving that heat through the food, effectively drying it out. These systems however, require quite big, intricate setups.
More simple diy dehydrators do work with a glass and having the food directly exposed to the sun.
For our first test we decided to make a combination of both; we will work with glass, a dark surface on the bottom of the dehydrator, and creating airflow by having the dehydrator sheets at an angle. We also created a design that will make it easy to take out and put in the food and something that is small enough to move around to find the ideal placement.
Our chosen design is based on the one shown in this video: https://www.youtube.com/watch?v=Cgoyeo25igo&t=217s
The reason we chose this to base our first test-dehydrator on is because it has following features:
- smaller (we don't have a lot of space to put it right now)
- 2 trays
- angle (kind of using the "moving airflow" concept of the more intricate designs)
- top part transparent
- bottom dark (to conserve the heat caught by the sun)
- sides fully closed (for bugs)
- back opens
- trays we can slide out to put the food
Testing the dehydrator in the wild
A lot of people like using the dehydrator for personal projects, here an update from Benno, who was a member of bread team in season 5:
"I dehydrated the following fruits and vegetables: figs, bellpepper, apple and tomato.
I cut all the fruits in small pieces, the figs in 1/8, bellpepper in 1cm pieces, tomato and apple in thin slices.
I always placed the fruit on their skin so they wouldn't stick.
For all the fruit one sunny day was enough to dry them in a way we could use them for the bread. The figs were not fully dry after one day i would say. So maybe they need two days if you want to store them for a longer time. Or maybe it works in the summer months.
I changed the position of the dehydrater at least 3 times a day to have the sun at the perfect angle. I also changed the upper and lower trays once a day so everything gets the same amount of sun.
A design flaw of the current dehydrator is that the trays are at an angle. That leads to fruit rolling over which then stick to the mesh.
We used the dehydrated fruit mostly for bread. Fig and sunflower seed bread was good as well as bread with the tomatoes or bellpeppers. But some people seem to like the original bread more so we agreed on max. 3 special breads out of 10 breads"
During season 6 Cato tried to dehydrate the fruit we picked from our neighbors' trees, as seen in update #176.
Sadly, this didn't work quite as well. We had some issues with ants getting into the dehydrator, which Mariana helped us solve. We left the fruit to dry for two days, but it still didn't come out as we had hoped.
When comparing the differences from how Benno worked, we noticed a few differences:
- We tried to dehydrate fruit that contain more moisture (cherries and loquats).
- The loquats were cut into larger chunks than previously.
- Because the solution for the ant problem requires careful positioning of the bowls around the legs of the dehydrator, we didn't move it for optimal sun angle during the day.
We will need to experiment more with the dehydrator, and see if we can improve our design to be able to handle juicier fruits. Until then we will try drying foods that don't contain as much moisture.
Troubleshooting the issues
As shown in update #176, we had some trouble dehydrating fruit in our solar dehydrator.
Off camera we have tried drying herbs in the dehydrator, and while it took longer than expected, we managed to get good results.
To check how efficient the dehydrator is, we decided to record the temperature of it during different times of day.
Method: we used an infrared thermometer to check the temperature of the internal and external walls of the dehydrator, and documented the weather according to our basekamp system.
Internal temperature was measured as the average of the temperature of the east and west walls.
External temperature was measured as the average of the east, west, and south walls.
Day 1:
11am - internal temperature 37.6°, external temperature 36.1°, air temperature 28°, very clear sky.
2pm - internal temperature 39.8°, external temperature 40.9°, air temperature 32°, clear sky.
5pm - internal temperature 37.1°, external temperature 37.4°, air temperature 31°, slightly cloudy.
Day 2:
11am - internal temperature 33.5°, external temperature 34.2°, air temperature 23°, slightly cloudy.
2pm - internal temperature 35.5°, external temperature 36.7°, air temperature 26°, slightly cloudy.
5pm - internal temperature 36.9°, external temperature 37.4°, air temperature 27°, slightly cloudy.
The results seem to be fairly consistent, with the inside of the dehydrator being slightly colder than the outside, but still significantly warmer than the air temperature.
To further test the dehydrator, we decided to place pieces of broken tile on both trays of the dehydrator, as well as a control piece outside the dehydrator, to simulate how hot the food itself would get.
Once again, we used the infrared thermometer, and calculated the average of the measurements of each group.
The bottom tray was the coldest, at 36°. Still warmer than the air temperature of 33°, but only slightly.
The top tray and the tiles outside were basically the same temperature, at 45.1° and 45.3° respectively. Significantly warmer than the air temperature.
This confirmed the finding of the first test, and let us know that while the food in the dehydrator gets hotter than if we were to hang it in the shade, it doesn't show any significant difference than laying it out in the sun.
Of course, the dehydrator protects the food from insects (mostly), and the wind, which is still useful, so we will keep using this prototype until we find a better solution to drying our food
Trying to resolve our current issues with small fixes
To try and upgrade the solar dehydrator so it functions better, we need to look at the problems we run into and which of those we can fix with a simple change.
Dehydration
At the moment, drier fruits that are cut into very small pieces (figs, peppers, ..) dry properly. Also herbs dry well. However as soon as we put fruits with a higher water content, we do not get good results.
The main reason for this is not the temperature of the solar dehydrator, but the fact that the humidity doesn’t leave.
For this, there should be better airflow. To force the air we created an opening at the bottom in the front side, and at top in the back side, which would give us some airflow. However this does not seem to be giving enough airflow for our required results.
Solution: Adding a small solar powered fan could help solve this and likely give us better results.
Temperature
With our current setup the inside is an average of 30% warmer than the outside, the max temp we have reached is 39.8degrees.
To have a more sufficient dryer we would like to reach warmer temperatures (The ideal temperature to reach is between 40°C and 60°C). A few ways to do this is:
- insulate all non-glazed surfaces (still leaving room for moisture to escape)
- paint it black inside and out: black surfaces absorb, then re-radiate the sun's heat in a longer wavelength of infra-red, which doesn't pass through glass as easily as the short wavelengths the sun emits.
Some of you have suggested foil lining; however this does not seem to be a good solution: you don't want to send heat back out through the glazing by reflecting it off a mirror.
Preserving more nutrients
A box solar dehydrator placed directly in the sun will lead to a loss of vitamins and nutrients. To avoid this the solution would be to build an indirect solar dehydrator.
Pests
For now, the legs of the dehydrator are placed in water to deter pests like ants. Another interesting idea to try is painting the bottom part with lime, as suggested by user ichilli. It is a technique used to deter pests from trees, and solves our rotting wood issue. It would be good to make the legs a bit taller, as to avoid ants still using nearby grass or structures to bypass the lime paint.
